error: result is above max
error: result is above max - 消息
#1 已发布: 2021/5/28 10:21:06
takeo kusumi
takeo kusumi
0个赞,共3个帖子。
hi,
I'm a beginner
I get an error in the calculation
error :
result is above max. Allowed positive number
How can I solve it?
impedance.sm (34.02 KiB)已下载 1230 次。
#2 已发布: 2021/5/28 10:39:29
600个赞,共1,381个帖子。
hi,
I'm a beginner
error :
How can I solve it?
Change your calculation result from symbolic to numeric.
You can do it with eval() since they are all numbers.
#3 已发布: 2021/5/28 15:27:57
takeo kusumi
takeo kusumi
0个赞,共3个帖子。
Thank you
I understand the cause of the error
#4 已发布: 2021/5/28 18:40:26
983个赞,共6,866个帖子。
eval() is a general rule but an absolute rule.
Many projects fail from eval(,).
SS 6179 does not complain as you constructed.
eval(,) is applied afterwards to isolate/accelerate.
#5 已发布: 2021/5/28 20:33:21
983个赞,共6,866个帖子。
Good application case to globalize within the program.
... in my SS 6179 timing drops from 2.6 s down to 1.6 s
#6 已发布: 2021/5/28 20:55:57
takeo kusumi
takeo kusumi
0个赞,共3个帖子。
Thank you.
I was able to calculate the frequency characteristics
(PP2.sm)
But when I modify a circuit, I get an error even with eval.
(PPS.sm)
it's very difficult.
PPS.sm (176.46 KiB)已下载 1233 次。
PP2.sm (167.69 KiB)已下载 1236 次。
#7 已发布: 2021/5/29 10:50:48
983个赞,共6,866个帖子。
Thank you.
(PP2.sm)
(PPS.sm)
... sorry, can't help: this document opens freak SS 6179.
You seem to put too much that can't be debugged piece wise.
#8 已发布: 2021/5/29 12:11:55
1,139个赞,共1,805个帖子。
Thank you.
(PP2.sm)
(PPS.sm)
Hi Takez. Yes, it's very difficult recognize or even guess where the program needs some evals. Also, putting them everywhere make unreadable the procedures. In the case of your PPS.sm that's SMath stores into Z without eval
and this with it
So, for PPS.sm there is where you need to use eval, and seems that then all other calculations works.
#9 已发布: 2021/5/29 12:33:20
600个赞,共1,381个帖子。
Razonar's is the correct solution.
Deleting my post.
Alvaro 2021/5/29 17:56:00
