Possible problematic assignment!
Possible problematic assignment! - 消息
#1 已发布: 2010/3/16 16:00:04
325个赞和1个踩,共2,052个帖子。
Hello Andrey,
I would suggest to change the assignment operator ( := ) behavior. Just look at this, please:
[MATH]x←5+6[/MATH]
[MATH]x=5[/MATH] WRONG!
This is because we can type something like this:
x:5[SPACE]+6
This can be hard to trace. Fortunately, we can put the mouse on the region and see the probem, if the expression is simple. If the expression is a bit more complicated we might not see where the problem was. Just a single careless [SPACE] might make a problem.
I suggest (if possible) not to allow inserting anything when, say, this is the case:
Inserting any operator, or anything else should be simply disabled.
