When you studied Chemistry, balancing equation was about integer valence(s).
This is solving Diophantine. Chemical balance may be wrt non-integer valence(s).
No direct solver(s) will do. The system must be put in form of matrix,
then create the PseudoInverse that will solve.
Solve Diophantine Chemical Balance.sm (47.55 KiB)已下载 1248 次。Matrix PseudoInverse.sm (111.21 KiB)已下载 1272 次。
