The construction of a sphere with respect to four given points
The construction of a sphere with respect to four given points - 消息
#1 已发布: 2017/12/18 05:34:01
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
http://mathworld.wolfram.com/Circumsphere.html
1.We compose the equation of the circle for each of the four points.
2.We subtract the fourth equation for each of the first three equation
to get three linear equations with three unknown coordinates of the center.
3.Solving the system of three linear equations.
Sphera4p.sm (21 KiB)已下载 1364 次。
#2 已发布: 2017/12/18 14:57:52
983个赞,共6,866个帖子。
Thanks Ber7 ... guess what I guess,
I guess you will have more of those very educative Smath stuff, is it !
#3 已发布: 2018/7/17 02:52:25
Adriaan Knox
Adriaan Knox
0个赞,共25个帖子。
May I ask what the purpose is of setting some of the equations equal to a string with the Boolean equals operator?
#4 已发布: 2018/7/17 08:55:47
Arie
Arie
94个赞,共285个帖子。
It just allows one to describe the equation. Note that the assignment operator is used in parenthesis. This actually performs the assignment to the variable.
If you were to actually evaluate the expression, it would evaluate to 0 (False). This makes sense because the string is not equal to the value assigned.
bdrunagle 2018/7/17 15:58:00
