Help converting thermal units.
Help converting thermal units. - 消息
#1 已发布: 2014/6/12 14:51:21
drewbagel423
drewbagel423
0个赞,共4个帖子。
Not sure if this is the right place. But I'm trying to convert heat transfer units like BTU/hr-ft-F to W/m^2-K. It seems like SMath can convert temperature units by themselves, but not when combined with other units. Unless I'm doing something wrong.
#2 已发布: 2014/6/12 15:33:25
325个赞和1个踩,共2,052个帖子。
The simplest answer is that you can not use Celsius and Fahrenheit (relative scales) but use Kelvin and Rankine (absolute scales). You should use them like in the picture. Define a temperature differences and then use them in heat transfer units (or just use Kelvin and Rankine instead of Celsius and Fahrenheit)
#3 已发布: 2014/6/17 12:15:33
drewbagel423
drewbagel423
0个赞,共4个帖子。
Thanks! That's very helpful!
