1页(5条)
Thousands Separator - 消息
Hey guys, I'm a new user of SMath Studio (I like it so much that I'm coding some routines I use to work in this software
Anyway, I'd like to know if there's a way to format the values given in the output result, from 3000000,00 to 3.000.000,00, for example, using periods as thousands separator.
Thanks in advance.
PS.: Sorry for my bad english. :/
Thanks in advance.
Wrote3000000,00 to 3.000.000,00
3.000.000,00 that does not exist.
space separators 3 000 000,00 are prone to typo error.
Let's read more comments/suggestions.
I just noticed that SMATH doesn't have engineering format; per thousand. Anyway, not what you are looking for but for consideration you can create a unit per thousand like accountants use Roman "M".Acct. Style.sm (4.68 KiB)已下载 1198 次。
Norm
Norm
For a better presentation's quality it is needed a thousands separator, as well as the decimal separator already available.
It's also a very good enhancement to help the "finishing" of documents.
WroteIt's also a very good enhancement to help the "finishing" of documents.
Not so much use, whereas no CAS displays/accesses > 15 figures
Utilities Round(U,n).sm (13.18 KiB)已下载 1167 次。
1页(5条)
