function call from function
function call from function - bug or feature ? - 消息
#1 已发布: 2016/10/6 14:56:16
Igor Skarine
Igor Skarine
14个赞,共97个帖子。
Please look at the attached worksheet.
function inv_sn(x,k) works fine in the main body, but fails is called from another function.
inv_sn.sm (4.61 KiB)已下载 1338 次。
#2 已发布: 2016/10/6 17:28:44
CBG
CBG
78个赞,共312个帖子。
You have to first define the function "sn".
To evaluate "tttt" uses the "=" not ": =".
#3 已发布: 2016/10/6 19:24:27
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
It should be noted that sn() seemingly depends on uni's EFI for Mathcad libraries; also, it's 32-bit only iirc. So, it OP wants others to see what he sees, he should mention the dependencies.
Here's what e.g. I see:
С уважением, Михаил Каганский
#4 已发布: 2016/10/6 23:15:53
983个赞,共6,866个帖子。
... previously answered but let's see it.
