How to see arithmetic??
How to see arithmetic?? - 消息
#1 已发布: 2009/1/15 23:31:04
Bardock
Bardock
0个赞,共1个帖子。
It is possible to see arithmetic, in example on summation?? Not only a result ?
And another question:
If I want sum 2 diffrent Matrix, in example 2 column/3 verse and 4 column/2 verse is it possible to do this ??
#2 已发布: 2009/1/16 00:21:43
2,344个赞,共4,057个帖子。
组: Super Administrator
Not sure that I understand your question... If you mean that you want to see every step of the calculation, then no. Program could only show you a result.
There is no rules in math to do this. Matrices could be summed up only if the number of rows and columns of both matrices are equal.
