Paste on the canvas causes unhandled exception - 消息
P.S. this not happens using the nightly build 0.96.4909
引用Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
sono riportate in fondo al messaggio.
************** Testo dell'eccezione **************
System.NullReferenceException: object reference not set to an instance of an object.
in SMath.Control.Worksheet.(String )
in SMath.Control.Worksheet.Insert(String value)
in SMath.Control.WorksheetControl.OnKeyDown(KeyEventArgs e)
in System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
in System.Windows.Forms.Control.WmKeyChar(Message& m)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
best regards,
Davide
May it be caused by some plug-in installed? If you will find it out I hope to find a way to prevent such kind of problems in future.
1. Open installed 0.97 with nearly all plugins enabled.
2. paste "ddd " to the canvas - a hyperlink region with that string appears
3. Switch off Hyperlink Region in the extension manager
4. paste "ddd " again - a snapshot region appears
5. Disable snapshot region as well
6. Again pasting "ddd " - a crash happens with the following details:
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei SMath.Control.Worksheet.(String )
bei SMath.Control.Worksheet.Insert(String value)
bei SMath.Control.WorksheetControl.OnKeyDown(KeyEventArgs e)
bei System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
bei System.Windows.Forms.Control.WmKeyChar(Message& m)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 2.0.0.0.
Win32-Version: 2.0.50727.5472 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll.
SMathStudio_Desktop
Assembly-Version: 0.97.5154.6566.
Win32-Version: 1.1.27.0.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMathStudio_Desktop.exe.
Win32-Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
Win32-Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
ioman
Assembly-Version: 0.97.5154.6193.
Win32-Version: 0.97.5154.6193.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/ioman.DLL.
System.Windows.Forms.resources
Win32-Version: 2.0.50727.5420 (Win7SP1.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
canvas
Assembly-Version: 0.97.5154.6194.
Win32-Version: 0.97.5154.6194.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/canvas.DLL.
rview
Assembly-Version: 0.97.5154.6223.
Win32-Version: 0.97.5154.6223.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/rview.DLL.
System.Xml
Win32-Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll.
MathcadFileAccess
Assembly-Version: 1.0.5036.4937.
Win32-Version: 1.0.5036.4937.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/02a1c2c5-590e-46bb-bcf6-c87856a8b14b/1.0.5036.4937/MathcadFileAccess.dll.
NuLib
Assembly-Version: 1.64.5154.6194.
Win32-Version: 1.64.5154.6194.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/NuLib.DLL.
SliderRegion
Assembly-Version: 0.1.5155.20133.
Win32-Version: 0.1.5155.20133.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/0c864749-6fe8-4f62-a74d-f6ac601e52a5/0.1.5155.20133/SliderRegion.dll.
customFunctions
Assembly-Version: 1.0.4902.41872.
Win32-Version: 1.0.4902.41872.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/18dadffd-79a3-4cf9-aee1-d66deb0ea720/1.0.4902.41872/customFunctions.dll.
FIRFilterDesign
Assembly-Version: 1.0.4972.7542.
Win32-Version: 1.0.4972.7542.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/191f7c7a-6b6e-4af0-8bb7-c7a202d59cd4/1.0.4972.7542/FIRFilterDesign.dll.
FunctionsExtension
Assembly-Version: 0.0.5093.5251.
Win32-Version: 0.0.5093.5251.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/24c691c1-37f2-49e3-9a84-ccb77304d14a/0.0.5093.5251/FunctionsExtension.dll.
ComboBoxRegion
Assembly-Version: 0.1.5146.31497.
Win32-Version: 0.1.5146.31497.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/28ea70bd-1dee-4200-b2e1-1d53d5832487/0.1.5146.31497/ComboBoxRegion.dll.
MapleWrapper
Assembly-Version: 1.0.4972.7570.
Win32-Version: 1.0.4972.7570.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/32dfd679-8cfd-483a-b79a-19d5ea838750/1.0.4972.7570/MapleWrapper.dll.
mscorlib.resources
SMathFinancials
Assembly-Version: 1.0.4928.30282.
Win32-Version: 1.0.4928.30282.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/36acfa39-f2ec-4733-9b68-6f96426f672a/1.0.4928.30282/SMathFinancials.dll.
NumericUpDownRegion
Assembly-Version: 0.1.5150.34772.
Win32-Version: 0.1.5150.34772.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/43438e49-5428-4036-8991-ce03b1d1e572/0.1.5150.34772/NumericUpDownRegion.dll.
MaximaPlugin
Assembly-Version: 1.97.5154.316.
Win32-Version: 1.0.0.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.97.5154.316/MaximaPlugin.dll.
HyperlinkRegion
Assembly-Version: 1.0.5146.28506.
Win32-Version: 1.0.5146.28506.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/4938d1a8-ad11-4de8-afbf-d76d069cfbf8/1.0.5146.28506/HyperlinkRegion.dll.
MatlabCppMathLibrary
Assembly-Version: 1.0.4987.26944.
Win32-Version: 1.0.4987.26944.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/4c2faab1-4d93-4904-8d88-a4e21512d179/1.0.4987.26944/MatlabCppMathLibrary.dll.
CurrencyUnits
Assembly-Version: 0.1.5117.2578.
Win32-Version: 0.1.5117.2578.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dbac4cd-5f31-4a17-982e-f3233b0546de/0.1.5117.2578/CurrencyUnits.dll.
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
DataExchange
Assembly-Version: 1.0.5146.30776.
Win32-Version: 1.0.5146.30776.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.5146.30776/DataExchange.dll.
Ionic.Zip
Assembly-Version: 1.9.1.8.
Win32-Version: 1.9.1.8.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.5146.30776/Ionic.Zip.dll.
NonlinearSolvers
Assembly-Version: 1.0.9999.5.
Win32-Version: 1.0.9999.5.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/618b7e96-330a-406a-b055-9e577672f0b8/1.0.9999.5/NonlinearSolvers.dll.
ImageRegion
Assembly-Version: 1.0.5149.39321.
Win32-Version: 1.0.5149.39321.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/ImageRegion.dll.
SharpVectors.Core
Assembly-Version: 0.3.1.1588.
Win32-Version: 0.3.1.1588.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Core.dll.
SharpVectors.Css
Assembly-Version: 0.3.1.1590.
Win32-Version: 0.3.1.1590.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Css.dll.
SharpVectors.Dom
Assembly-Version: 0.3.1.1589.
Win32-Version: 0.3.1.1589.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Dom.DLL.
SharpVectors.Model
Assembly-Version: 0.3.1.1592.
Win32-Version: 0.3.1.1592.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Model.dll.
SharpVectors.Rendering.Gdi
Assembly-Version: 0.3.1.1595.
Win32-Version: 0.3.1.1595.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Rendering.Gdi.dll.
StatisticalTools
Assembly-Version: 1.0.4902.38391.
Win32-Version: 1.0.4902.38391.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/76f6e9f5-ac86-4ffb-9e4d-284c8daecaf9/1.0.4902.38391/StatisticalTools.dll.
ExcelFileType
Assembly-Version: 1.3.5031.1884.
Win32-Version: 1.3.5031.1884.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/ExcelFileType.dll.
ICSharpCode.SharpZipLib
Assembly-Version: 0.86.0.518.
Win32-Version: 0.86.0.518.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/ICSharpCode.SharpZipLib.dll.
NPOI
Assembly-Version: 2.0.1.0.
Win32-Version: 2.0.1.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.dll.
NPOI.OOXML
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.OOXML.dll.
NPOI.OpenXmlFormats
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.OpenXmlFormats.DLL.
NPOI.OpenXml4Net
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.OpenXml4Net.dll.
SnapshotRegion
Assembly-Version: 1.0.5147.33684.
Win32-Version: 1.0.5147.33684.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/9166ba14-4cd9-47f6-b988-e96526b16cc9/1.0.5147.33684/SnapshotRegion.dll.
mcadefi
Assembly-Version: 1.0.4977.35617.
Win32-Version: 1.0.4977.35617.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/91a20d24-c30b-4774-9b1b-4d502a80420f/1.0.4977.35617/mcadefi.dll.
CFLabelRegion
Assembly-Version: 1.0.5146.41812.
Win32-Version: 1.0.5146.41812.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/a43ac8f9-29d7-4e8a-9ad0-82cf7c4e14f6/1.0.5146.41812/CFLabelRegion.dll.
PdfFileType
Assembly-Version: 1.0.5146.31046.
Win32-Version: 1.0.5146.31046.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.5146.31046/PdfFileType.dll.
PdfSharp
Assembly-Version: 1.32.2608.0.
Win32-Version: 1.32.2608.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.5146.31046/PdfSharp.dll.
CheckBoxRegion
Assembly-Version: 1.0.5146.31372.
Win32-Version: 1.0.5146.31372.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/aeb799ab-3afc-4a82-8f44-27d03df672ca/1.0.5146.31372/CheckBoxRegion.dll.
XYPlotRegion
Assembly-Version: 0.1.5151.38078.
Win32-Version: 0.1.5151.38078.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/c12231ec-4873-43c1-a7d0-a167ebd17066/0.1.5151.38078/XYPlotRegion.dll.
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll.
ModellerRegion
Assembly-Version: 1.0.5147.447.
Win32-Version: 1.0.5147.447.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/d5139464-68f1-4c95-bb0a-66f7ac41f86c/1.0.5147.447/ModellerRegion.dll.
netDxf
Assembly-Version: 0.1.2.0.
Win32-Version: 0.1.2.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/d5139464-68f1-4c95-bb0a-66f7ac41f86c/1.0.5147.447/netDxf.dll.
GPCWrapper
Assembly-Version: 1.0.4914.35302.
Win32-Version: 1.0.4914.35302.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f01/1.0.4914.35302/GPCWrapper.dll.
iode64
Assembly-Version: 1.0.4975.7445.
Win32-Version: .
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f06/1.0.4975.7557/iode.dll.
ODESolvers
Assembly-Version: 1.0.4975.7557.
Win32-Version: 1.0.4975.7557.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f06/1.0.4975.7557/ODESolvers.dll.
msvcm90
Assembly-Version: 9.0.30729.6161.
Win32-Version: 9.00.30729.6161.
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251/msvcm90.dll.
include
Assembly-Version: 1.0.5082.41871.
Win32-Version: 1.0.5082.41871.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/dfdcd1f7-5005-45f1-8bf8-016fb072ccf3/1.0.5082.41871/include.dll.
DevelopmentTools
Assembly-Version: 0.1.5154.548.
Win32-Version: 0.1.5154.548.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/f406188b-ff0e-4b02-8b05-8d6fda91e357/0.1.5154.548/DevelopmentTools.dll.
GNUScientificLibrary
Assembly-Version: 1.0.4988.38288.
Win32-Version: 1.0.4988.38288.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/fc3a9073-15c5-4991-b358-5ae635ae62d5/1.0.4988.38288/GNUScientificLibrary.dll.
gsl
Assembly-Version: 1.0.4988.38244.
Win32-Version: .
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/fc3a9073-15c5-4991-b358-5ae635ae62d5/1.0.4988.38288/gsl64.dll.
HTMLFileType
Assembly-Version: 1.13.5154.6538.
Win32-Version: 1.13.5154.6538.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/HTMLFileType.dll.
ImageFileType
Assembly-Version: 1.9.5154.6541.
Win32-Version: 1.9.5154.6541.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ImageFileType.dll.
PictureRegion
Assembly-Version: 1.10.5154.6544.
Win32-Version: 1.10.5154.6544.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PictureRegion.dll.
PlotRegion
Assembly-Version: 1.9.5154.6547.
Win32-Version: 1.9.5154.6547.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PlotRegion.dll.
SMathFileType
Assembly-Version: 1.9.5154.6550.
Win32-Version: 1.9.5154.6550.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SMathFileType.dll.
SpecialFunctions
Assembly-Version: 1.11.5154.6552.
Win32-Version: 1.11.5154.6552.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SpecialFunctions.dll.
TextRegion
Assembly-Version: 1.10.5154.6555.
Win32-Version: 1.10.5154.6555.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/TextRegion.dll.
ViewerFileType
Assembly-Version: 1.1.5154.6559.
Win32-Version: 1.1.5154.6559.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ViewerFileType.dll.
XMCDFileType
Assembly-Version: 1.12.5154.6563.
Win32-Version: 1.12.5154.6563.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/XMCDFileType.dll.
pi5vmt_s
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
I can repeat that.
What I cannot repeat: sometimes pasting creates a conditionally formatted label, but I did not yet recognize the pattern how to invoke that.
I've removed all the plugins and I can reproduce what Martin said...
The crash is caused by a third plugin, DevelopmentTools
- DevelopmentTools:
This code cause the crash (here the plugin doesn't override the Paste(IClipboardManager clipboard) function)
public string[] SupportedClipboardFormats
get { return new string[] { DataFormats.UnicodeText }; }
This solve the problem (at least for the users):
get { return new string[0]; }
Hyperlink & Snapshot Regions:
- SMath triggers the public override bool Paste(IClipboardManager clipboard) of any available plugin, even if there aren't regions on the canvas (but this should happens only if a region exists and is focused)
WroteWhat I cannot repeat: sometimes pasting creates a conditionally formatted label, but I did not yet recognize the pattern how to invoke that.
I don't have noticed the bug in the front-end, but I've fixed the code as for the Development tools and I've pushed in the EM an update
