Plugin installation fails
Plugin installation fails - Multiple plugins fail to install - 消息
#1 已发布: 2022/12/13 23:43:51
CBG
CBG
78个赞,共312个帖子。
Hello
I can't install several plugins, see attached image
#2 已发布: 2022/12/14 10:33:39
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Hello Carlos,
I have no such problem.
Hope somebody will help you.
#3 已发布: 2022/12/14 22:38:35
CBG
CBG
78个赞,共312个帖子。
Hello NDTM
Thank you very much, I also hope that someone can solve the problem,
which seems to be something that always occurs in updates.
#4 已发布: 2022/12/15 06:35:28
1,443个赞,共2,936个帖子。
It depends on the implementation of the interfaces between the program and the plugins, although I'm not sure why sometimes the plugin don't work for someone; usually is enough to recompile the plugin, sometime the code has also to be updated.
