1页(12条)
For loop - 1 seat every 30 people - 消息
Hi to everyone, I'm a new user of S-math.
I'm a newbie to programming.
Today I had to make a calculation to size the number of seats in a waiting room according to the total number of people.
The number of seats must be 1 for every 30 people.
I tried to make the calculation automatic via S-math, but I was unable. I thought the for loop might help me, but I don't know how. Can someone help me?
You should start from the problem itself... How would you solve it in mathematical or pseudocode form?
Hi I try to explain better what I want to calculate.
I would like to set up a for loop that allows me to do the same calculations as the if loop in the figure.
for example
if n.pers < 10 ---> n.s = 1
if n.pers > 10 & n.pers < 30 ---> n.s = 2
if n.pers > 30 & n.pers < 60 ---> n.s = 3
if n.pers > 60 & n.pers < 90 ---> n.s = 4
and so on
I don't know how if it's possible set up this cycle, anyway thanks.
for example
and so on
WroteHi I try to explain better what I want to calculate.
for example
and so on
You don't need an iteration.
Ceil() and cases() shall work for you.
Davide Carpi 2021/10/12 16:15:00
Hi
I'm probably doing something wrong because, for exemple, with 40 or 70 it doesn't work.
The suggestion of Overlord is correct. You can also define a function and make different corresponding values calculate (using the Vectorize function)
number_seat.sm (6.94 KiB)已下载 1295 次。
Thank to all. you are great!
I used an old version. Now work correctly in my pc, too.
Page8 Social.sm (16.79 KiB)已下载 1514 次。
WrotePage8 Social.sm (16.79 KiB)已下载 1514 次。
Not related with OP's question.
1页(12条)
