Graphing Problem
Graphing Problem - Can't graph piece wise function -SOLVED - 消息
#1 已发布: 2017/10/3 23:38:03
dlyon
dlyon
0个赞,共5个帖子。
I've tried many ways from examples I have found on the internet, but I just can't get the graph to plot. What am I doing wrong?
Any help would be greatly appreciated.
[b]Foot note:
The problems are solved. The main problem was units; units must be correct through out. When using constants be sure the value also has units attached (1.5 m, not 1.5, for example). The second was that for the extended graph plugin there seems to be a limit on the levels of conditional functions you can call. I ended writing the function as a one line which worked:
引用
m(x)={((x≥0m)&(x
#2 已发布: 2017/10/4 06:08:56
csb531
csb531
0个赞,共24个帖子。
Hello Dave,
maybe a simple scaling problem? Your results are of magnitude 8 N, your plot is in [kN].
Try scaling the plot area with [Ctrl]+scroll wheel or [Shift]+ scroll wheel.
Hope this helps...
Regards, csb.
#3 已发布: 2017/10/4 07:51:33
983个赞,共6,866个帖子。
Dave, please attach the work sheet.
#4 已发布: 2017/10/4 11:19:15
dlyon
dlyon
0个赞,共5个帖子。
Here Jean, thanks for looking
DaveMAST.sm (1.43 MiB)已下载 1314 次。
#5 已发布: 2017/10/4 12:07:09
1,443个赞,共2,936个帖子。
Input units are needed... in the standard 2D plot, just use p(x*'m) / V(x*'m)
#6 已发布: 2017/10/4 12:18:53
983个赞,共6,866个帖子。
1. The X_Y plot does not take conditional
2. Quick plot does not take units [there is way to trick]
3. units removed from the two conditional ... plots !!!
Cheers... Jean
MAST.sm (1.43 MiB)已下载 1306 次。
#7 已发布: 2017/10/4 13:31:53
dlyon
dlyon
0个赞,共5个帖子。
Yahoo! Thanks Jean! I understand the problem!
Dave
