Table of contents with link - 消息
I have been using Smath for the last two years, but only basic stuffs.
Right now, I have a document that's a little bit long and I would like to add a table of contents with the ability to jump to the chapters, like in Word.
Is there a way to achieve this?
WroteRight now, I have a document that's a little bit long and I would like to add a table of contents with the ability to jump to the chapters, like in Word.
Not sure what's too long ...
If the table per chapters, then sub-collect.
Please, attach the table imported in Smath.
Cheers ... Jean.
Here is the link for his last example/sample about your toc request.
https://en.smath.com/forum/yaf_postsm51476_Automatic-numbering-sections-book.aspx#post51476
Project Data Analysis Statistical Histogram..sm (91.73 KiB)已下载 1329 次。
This reply doesn't contain a TOC or something similar.
Not related with OP's request. Jean is being Jean, again..
The interactive handbook is an example of such a document. In the early years this approach required editing of the xml contents of the sm files, based on inspection of Andrey's math reference book.
Davide has provided the Text region utilities plugin, which provides means to edit these links from within SMath Studio. The "toolbox" also provides batch generation of links to all files in a given directory. Unfortunately, this doesn't work any more in recent SMath versions.
At least in build 7579 it worked.
The link text can be generated based on file name (as in the screen shot) or based on title or description from the metadata (File> Properties)
![2022-01-30 20_20_39-SMath Studio 0.99.7579 - [TOC.sm_].png](/zh-Hans-CN/files/Download/6NwzVa/2022-01-30-20_20_39-SMath-Studio-0.99.7579---[TOC.sm_].png)
WroteWroteRight now, I have a document that's a little bit long and I would like to add a table of contents with the ability to jump to the chapters, like in Word.
Cheers ... Jean.
Hi Jean, thank you for your reply, but I am not sure I understood it. Maybe I wasn't clear, I have attached an image of what I pretend.
WroteCheck for Razonar's replies under this topic.
Hi Razonar, thank you for your reply. I downloaded the file, I think the table of contents is not clickable right? So, I would like to click over some chapter in the Table of Contents and Smath automatically jumps to the page where the chapter is located.
WroteComplex documents can be split into individual sm files which can be cross-referenced by text regions with active links.
Hi mkraska, thank you for your reply. I saw that option too, thanks. If I don't find a way of doing everything in the same documents, I may do that yes.
WroteHi Jean, thank you for your reply, but I am not sure I understood it. Maybe I wasn't clear, I have attached an image of what I pretend.
Attach your 3 Chapters as 3 clean images from Word.
I will make them brute force accessible.
Cheers ... Jean.
I have to check the recent improvements by Andrey but my latest attempt to implement TOC in WriterRegion wasn't good enough for some limitations, I'll give it another try soon.
WroteAt least in build 7579 it worked.
Thank you, I see it doesn't works anymore as expected. I'll check it too.
WroteOk Thank you everyone.
In the mean time you have Go to page
from the coded TOC, you can survive/access ▄ this demo.
Very easy to sanity QA my for 4 Clients from remote.
BTW, the Mathsoft page hyperlink was tested only, never used
in the Mathsoft Collaboratory over 10 years I shared.
Cheers, best ... Jean.
TOC [4 Clients Model].sm (205.29 KiB)已下载 1080 次。
WroteTOC [4 Clients Model].sm (205.29 KiB)已下载 1080 次。
This is not a TOC example. This is not even a workaround for a TOC.
I can't even describe what kind of a monstrosity reply this is.
WroteThis is not a TOC example.
This is not a TOC ... a hyperlink to regions of a work sheet.
"As for now an hyperlink approach like those proposed above is available/useful only if the contents are in different worksheets. I have to check the recent improvements by Andrey but my latest attempt to implement TOC in WriterRegion wasn't good enough for some limitations, I'll give it another try soon.
Thank you, I see it doesn't works anymore as expected. I'll check it too."WroteAt least in build 7579 it worked.
