1 Pages (5 items)
[XY plot region] dialog prompted on missing screen lock the program - X-Y Plot format dialog does not pop up - Messages
Started having this issue in the afternoon US time {AppVersion 0.99.6671}. I deleted the plugin as well as C:\Users\{username}\AppData\Roaming\SMath\extensions\plugins\c12231ec-4873-43c1-a7d0-a167ebd17066 and restarted my computer.
I reloaded the plugin. Opened attached files and system locks up.
UPDATE: Plugin opens fine on 0.99.6661 portable version
WroteQuick Sound Loss (1)_r1.sm (140.03 KiB) downloaded 1162 time(s).
WroteQuick Sound Loss (3).sm (140.83 KiB) downloaded 1120 time(s).
I cannot reproduce... could you paste the "System informations" result of Development tools plugin?
Have you deleted the c12231ec-4873-43c1-a7d0-a167ebd17066 folder, only the latest plugin subfolder, the library... (asking because an improper deletion might cause effects unrelated with the initial bug).
To exclude/restrict interferences between plugins you can even rename the whole %APPDATA%\Smath folder (and restore it back deleting the new one that will be created, after you tested the worksheets)
WroteI deleted the plugin as well ...
ElSid 2018/4/11 12:26:00
Davide,
I think I found the culprit. Same computer, same install as issue last night. This morning, I'm at office and the "Formatting" dialog box opens up on my second screen. This is funny because my desktop is on my second screen, but when undocked, it all reverts back to my laptop monitor. It appears as if the "Formatting" dialog box does not revert back to the main screen.
WroteIt appears as if the "Formatting" dialog box does not revert back to the main screen.
Correct, looking at the code seems a feature (he remember where it was last time you used it); I think that Viacheslav can fix it easily, disabling the feature or by adding a check on coordinates and available screens.
In the meanwhile, when this happens, you can use ALT+F4 to close the hidden form
WroteFound the issue(s). See revamped file. Still having issues in that X-Y plot Labels for the legend *zap*Quick Sound Loss.smz (142.28 KiB) downloaded 1484 time(s).
Edit: Two bugsThis is one of those sheets where UNITS are huge! The equations are all based off of SI/metric references. Major issue
- X-Y Plot. If functions crash, *Zap* to the legend titles. All other titles OK. Legend is empty due to laziness after last 5 crashes
- solve(4) did not like trying to cancel units in the denominator of the final function (#dist). As I was adding units to x:0-100 FT and dividing the units meters in the function, the function crashed in the solve block (Just the function, with all values plugged in except for x = vector, so it's a solve(4) issue).
There is additional documentation and function definition updates. Sanity check the graph x scale (adjusted for feet since I'm in the US). Should be good now
1 Pages (5 items)
