Polygon intersection
Polygon intersection - 消息
#1 已发布: 2020/5/17 16:24:07
SteelCat
SteelCat
3个赞,共47个帖子。
Hi everyone,
I'm looking for suggestions to find the intersection of two polygons and hatch the result.
The most particular case concerns the hatching of a part of polygon intersected by a straight line.
I know some basic of X-Y plot to draw a polygon...
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
#2 已发布: 2020/5/17 17:12:07
1,362个赞,共2,276个帖子。
Perhaps the GPC (general polygon clipping library) wrapper plugin might help. The basics are described in section G.3 of the german handbook.
You also might have a look at the hatch and fill snippet.
GPC.sm (6.8 KiB)已下载 1907 次。
frapuano 2020/5/18 04:10:00
#3 已发布: 2020/5/18 11:04:20
983个赞,共6,866个帖子。
Otherwise, piece wise from native Smath ... just demo.
Circular Polygon.sm (20.93 KiB)已下载 1246 次。
#4 已发布: 2020/5/18 12:31:53
1,139个赞,共1,805个帖子。
Hi. Maybe you also can check this discussion: https://en.smath.com/forum/yaf_postst11405_Line-intersections.aspx
#5 已发布: 2020/5/18 20:56:55
983个赞,共6,866个帖子。
IMHO, I don't see much interest for polygon intersection.
For your interest: Intersection Pentastar.
Maths Polygon Solve Intersection.sm (21.94 KiB)已下载 1174 次。
Maths Polygon Intersection Pentastar.sm (35.97 KiB)已下载 1186 次。
#6 已发布: 2020/5/18 22:32:09
983个赞,共6,866个帖子。
...labels added, superb for publishing.
Maths Polygon Intersection Pentastar.sm (47.19 KiB)已下载 1178 次。
#7 已发布: 2020/5/19 11:38:48
SteelCat
SteelCat
3个赞,共47个帖子。
thank you all, I will do some application
#8 已发布: 2020/5/23 06:37:34
ianlh
ianlh
0个赞,共38个帖子。
Question:
How would you then calculate / determine the length of the clipped line?
Interested for tension and shear lengths in unusual shapes
#9 已发布: 2020/5/23 11:24:32
983个赞,共6,866个帖子。
... refreshed/generalized/augmented [A, P, CG]
2D Plot Setup Critical Polygon Intersection.sm (31.89 KiB)已下载 1303 次。
#10 已发布: 2020/5/23 13:04:57
983个赞,共6,866个帖子。
From the attached Smath document.
#11 已发布: 2020/5/23 13:11:13
SteelCat
SteelCat
3个赞,共47个帖子。
Question:
From coords, using Pitagora's theorem
Very nice.
