Disable Evaluation
Disable Evaluation - In a part of program - 消息
#1 已发布: 2023/5/27 05:05:26
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
It will be good!
#2 已发布: 2023/5/27 08:07:26
983个赞,共6,866个帖子。
It will be good !
We have it algo style...
Lot more powerful/simpler, composed @ will.
Cheers ... Jean.
Maths algo ADVANCED.sm (15.43 KiB)已下载 1700 次。
#3 已发布: 2023/5/27 08:46:20
Oscar Campo
Oscar Campo
135个赞,共309个帖子。
It will be good!...
Putting that block between quotation marks ("..." ) is a tricky option. That converts that block into a text or a "commentary" to your code. When you need that block to be evaluated, copy the text between the quotation marks and paste it into the code.
Example:
Now the block is a "commentary":
Revert the process to enable evaluation
Best,
Oscar
