solve() by Maple Plugin gives an "arctan() function not defined" error
solve() by Maple Plugin gives an "arctan() function not defined" error - solve() by Maple Plugin gives an "arctan() function not defined" error - 消息
#1 已发布: 2013/5/29 12:24:16
Oscar Campo
Oscar Campo
135个赞,共309个帖子。
I found this behavior working with Maple plugin:
I think that it would be easily fixed by uni
Thanks in advance!
Oscar
#2 已发布: 2013/5/29 12:53:16
1,443个赞,共2,936个帖子。
@uni
I think that you can use directly:
ExpressionString = ( new Regex( @"\batan\(" ) ).Replace( ExpressionString, Functions.Arctg + @"(" );
ExpressionString = ( new Regex( @"\barctg\(" ) ).Replace( ExpressionString, Functions.Arctg + @"(" );
using the Functions.* you don't need to write the right SMath function name.
best regards,
w3b5urf3r
#3 已发布: 2013/5/29 21:17:53
1,558个赞,共1,868个帖子。
Oscar, could you attach the file and the log (mvr5.txt)? As for me your example works fine.
@w3b5urf3r
Thanks, I forgot about that.
#4 已发布: 2013/5/30 17:58:33
Oscar Campo
Oscar Campo
135个赞,共309个帖子。
Here the files.
Thanks in advance!
Oscar
#5 已发布: 2013/5/31 10:19:11
1,558个赞,共1,868个帖子。
Here the files.
Thanks in advance!
Oscar
Fixed and updated. Try now.
