Mono: crash on Ubuntu 16.04
Mono: crash on Ubuntu 16.04 - 消息
#1 已发布: 2017/11/9 14:47:09
philippe dalet
philippe dalet
18个赞,共34个帖子。
Hello
I've tested SMathStudio (SMathStudioDesktop.0_98_6520.Mono.tar.gz) on linux
and it can't start.
VERSIONs TESTED
Mono JIT compiler version 5.4.0.201
Ubuntu trusty 1404
Mono JIT compiler version 3.2.8
Ubuntu xenial 16.04
Does anyone know the solution?
Greeting,
Philippe
Sorry, I forgot the error message
smathstudio_startup_error.txt (67.04 KiB)已下载 1300 次。
#2 已发布: 2017/11/9 18:59:34
2,344个赞,共4,057个帖子。
组: Super Administrator
Seems this is something I must look at before stable release. I will...
Thank you Philippe!
#3 已发布: 2017/11/10 12:52:57
1,558个赞,共1,868个帖子。
The same error with 0.98.6522.
#4 已发布: 2017/11/11 07:10:55
philippe dalet
philippe dalet
18个赞,共34个帖子。
I found an origin of the crash on linux. The program cannot find a font, exactly MS sans serif.
I have put ms_sans_serif.ttf in ~./fonts. The error message changes.
tested on ubuntu 64 bits 16.04
SMathStudioDesktop.0_98_6523.Mono
Philippe.
Davide Carpi 2017/11/11 13:52:00
#5 已发布: 2017/11/19 19:21:47
2,344个赞,共4,057个帖子。
It should be fixed in latest beta. Could someone confirm with screenshot please?
#6 已发布: 2017/11/19 20:49:09
1,362个赞,共2,276个帖子。
SMath seems to ignore "portable.version"
I don't know where userdir is or how to otherwise clean up old plugins.
显示剧透
#7 已发布: 2017/11/20 05:14:17
1,443个赞,共2,936个帖子。
Same stack trace of Martin even in Linux Mint
It should be in ~/.config/SMath or in ~/.SMath
Martin Kraska 2017/11/20 05:43:00
#8 已发布: 2017/11/20 05:44:56
1,362个赞,共2,276个帖子。
Deleting the plugins doesn't help. Same crash, no matter if I run ./smathstudio_desktop_mono as root or as user.
It would facilitate testing if the portable.version wouldn't be ignored. Plugins are incompatible at times...
