TextRegionUtilities - Could not load file or assembly 'WriterRegion
TextRegionUtilities - Could not load file or assembly 'WriterRegion - Cannot install or disable TextRegionUtilities - 消息
#1 已发布: 2021/10/14 06:54:45
timgow
timgow
0个赞,共27个帖子。
I wished to install TextRegionUtilities but this failed, now I can't enable or disable it from the local Plugins list.
Please help, I don't know the next move.
Tim
#2 已发布: 2021/10/14 08:21:56
1,443个赞,共2,936个帖子。
If you install WriterRegion everything should works as intended again.
#3 已发布: 2021/10/14 11:10:48
timgow
timgow
0个赞,共27个帖子。
Hello Davide,
Thank you for lookin at this issue.
WriterRegion is installed. I uninstalled WriterRegion, closed, installed WriterRegion, closed, reopened but unfortunately still get the error.
Tim
#4 已发布: 2021/10/14 11:14:36
timgow
timgow
0个赞,共27个帖子。
Davide,
The enable & disable were greyed out but I didn't realize that the dustbin was active; I deleted and reinstalled, all ok now.
Many thanks,
Tim
