Strange Sin function error
Strange Sin function error - 消息
#1 已发布: 2011/11/23 12:16:12
Tatty-Drew
Tatty-Drew
0个赞,共1个帖子。
I was in the process of looking at some lifting structures and have managed to produce a very strange error.
I have derived an angle which I then use in a later Sin function. If I simply give an answer the result it correct but if I define a symbol to the function and check the value of the symbol the answer is hugely incorrect.
File can be found here:
http://files.engineering.com/getfile.aspx?folder=5166b729-a993-4a6f-8c50-243a4cca72c8&file=Sin_Error_-_Copy.sm
I have reproduced the error again at the bottom of the page with different values.
Wondered whether anyone can reproduce this error or offer any insight?
#2 已发布: 2011/11/23 14:48:16
Edward Ulle
Edward Ulle
21个赞,共182个帖子。
Try this. Change Optimization to Numeric.
First Select all SMath items.
From Calculation Menu -> Optimization -> Numeric.
I'm a civil engineer and perform a lot of structural calculations using SMath. Calculations with units helps to avoid errors, kips vs. lbs, inch vs. feet, etc. I have often encountered similar strange results and 99% of the time Optimization->Numeric solves the problem. I've found its important to display the results of each calculation just to see if it makes sense. I notice you're doing the same thing. Good engineering habit.
I wish default Optimization was Numeric. Don't know what Symbolic is used for.
Ed
