SMath论坛 SMath Studio Questions Error type conversion 1页(5条) Error type conversion - "IF" doest work well - 消息 转到最后一个帖子 #1 已发布: 2021/7/9 18:36:50 ricardo1894 0个赞,共2个帖子。 组: User 未找到文件。未找到文件。未找到文件。 #2 已发布: 2021/7/9 19:25:08 Oscar Campo 135个赞,共309个帖子。 组: Moderator Wrote未找到文件。未找到文件。未找到文件。Checking your sm file, by debugging, I found the term As.min is a complex number:Would you mind checking your numbers? #3 已发布: 2021/7/10 00:44:11 overlord 600个赞,共1,381个帖子。 组: Moderator oscampo is right about your functions.There are mistakes at this algorithm.Regards #4 已发布: 2021/7/10 22:02:22 ricardo1894 0个赞,共2个帖子。 组: User thanks u save me #5 已发布: 2021/7/11 14:46:37 Jean Giraud 983个赞,共6,866个帖子。 组: User Isn't the double loop should first produce Rn 10 x 10 matrix ?... then some suite wrt the project. 1页(5条) 有新帖 无新帖
