1页(4条)
Beta: SMath Studio 0.87.3719 (08 March 2010) - 消息
New SMath Studio 0.87.3719 Beta available
(Full description of the program can be found in Stable: SMath Studio 0.87 (10 February 2010) topic)
Last changes
- Added support of Units!
- Added ability to work with text inside math expressions!
- Data import implemented!
- Full changelog in progress...
Free Download
- Desktop Windows (desktop computer with Windows OS):
SMathStudioDesktop.0_87_3719.Setup.msi (Date: 08.03.2010. File size: 883KB)
SMathStudioDesktop.0_87_3719.Portable.exe (Date: 08.03.2010. File size: 16.44MB) - .Net Framework 2.0 doesn't required - Handheld (PPC, Communicator, Smartphone):
SMathStudioHandheld.0_87_3719.Setup.cab (Date: 08.03.2010. File size: 1.93MB) - * To install from the device
SMathStudioHandheld.0_87_3719.Setup.cab.zip (Date: 08.03.2010. File size: 441.58KB) - * To install from the device (archive with CAB inside)
SMathStudioHandheld.0_87_3719.Setup.exe (Date: 08.03.2010. File size: 495.28KB) - To install from the PC
Could you please to provide the Desktop Linux (mono).
Thanks, Waluyo
Thanks, Waluyo
Hello Andrey,
I've noted an issue about "Insert=>Function". In the dialog box when you choose "All" under Category, there are actually not all the available function given in the list. For instance, Programming and most of the String functions are not there. Moreover, I can not find "sum", "product", "diff", "int" function there. Dynamic assistance will give them all (I suppose) but not the "Insert=>Function". Actually, I could not find them there.
waluyo, ok, will do later today.
omorr, you are right. Will fix this.
1页(4条)
