SMath论坛 SMath Studio Questions graph problem 1页(4条) graph problem - 消息 转到最后一个帖子 #1 已发布: 2011/1/21 10:42:24 paolo1963 1个赞,共4个帖子。 组: User hello, I have a problem with the graphics, if I write a matrix as in the first case it prints regular graph, write it as if it does not print in the second case the graphthanks 1位用户喜欢此帖子Fridel Selitsky 2011/1/21 11:06:00 #2 已发布: 2011/1/21 11:12:55 Fridel Selitsky 520个赞,共451个帖子。 组: User c:=stack(a,b,d) #3 已发布: 2011/1/21 11:16:05 paolo1963 1个赞,共4个帖子。 组: User tanks #4 已发布: 2011/1/21 11:25:35 Oscar Campo 135个赞,共309个帖子。 组: Moderator Hi, you need use stack() function: 1页(4条) 有新帖 无新帖
