TinyPlugin
TinyPlugin - A guide to creating a simple extension. - 消息
#1 已发布: 2019/8/6 15:50:16
1,558个赞,共1,868个帖子。
SMath Studio compatibility Platform lang C# lang VB.NET
📝 Links:
1. How to create plugins for SMath Studio
2. Command-line build with csc.exe
3. Template project for numerical plugin (VS2017, .Net 2.0+, C#)
4. SMath Studio Core documentation (CHM)
5. Developer Guide (partially obsolete)
For c#:
1. Create file build.cmd
显示剧透
2. Create source file CSTinyPlugin.cs
显示剧透
3. Build assembly using command: build CSTinyPlugin.cs
Also you can use drag and drop technique for this.
You get CSTinyPlugin.dll
5. Copy CSTinyPlugin.dll to the C:\Program Files (x86)\SMath Studio\plugins folder and restart the program.
6. Test it.
7. Read the SMath Studio Core documentation: SSCoreDoc.chm.
2位用户喜欢此帖子
sergio 2019/8/6 16:11:00, Davide Carpi 2019/8/7 09:13:00
#2 已发布: 2019/8/6 17:28:27
1,558个赞,共1,868个帖子。
📝 Links:
2. Sample compilation command lines (Visual Basic)
3. Template project for numerical plugin (VS2017, .Net 2.0+, VB.Net)
For vb.net:
显示剧透
2. Create source file VBTinyPlugin.vb
显示剧透
3. Build assembly using command: build VBTinyPlugin.vb
You get VBTinyPlugin.dll
5. Copy VBTinyPlugin.dll to the C:\Program Files (x86)\SMath Studio\plugins folder and restart the program.
6. Test it.
frapuano 2019/8/7 11:22:00
