Most efficient way to build SMath matrix in VB.NET (plugin development)
Most efficient way to build SMath matrix in VB.NET (plugin development) - 消息
#1 已发布: 2015/12/7 18:23:57
Alexander O. Melnik
Alexander O. Melnik
127个赞,共498个帖子。
Hi all,
I have discovered recently that excel_IO plugin is way too slow in outputting LARGE excel ranges to SMath (30000+ elements).
The slowness narrows down to this part of the code:
        Dim myResult As List(Of Term) = New List(Of Term)
            For Each matValue As String In result_temp3
                myResult.AddRange(SMath.Manager.Converter.ToTerms(matValue))
            Next
            If counter > 2 Then
                myResult.AddRange(SMath.Manager.Converter.ToTerms(range_rows.ToString))
                myResult.AddRange(SMath.Manager.Converter.ToTerms(range_cols.ToString))
                myResult.Add(New Term(Functions.Mat, TermType.Function, (2 + (range_cols * range_rows))))
            End If
I am certain about the source of slowness because initially my code had two For Loops: one to format strings to satisfy SMath requirements and another one listed above. Later I have condensed those two For Loops into one. Performance DID NOT improve.
Is there any other way to pass a matrix to SMAth?
Any input is appreciated.
Thanks!
#2 已发布: 2015/12/8 14:11:52
dio pants
dio pants
16个赞,共180个帖子。
Alex-
What is the last line doing for you?
Are you trying to size/format the matrix and then populate it element by element?
The code is hard for me, so maybe I don't recognize your approach.
Could you simply read the data line by line and append the set with each one and then at the end with range_rows, range_columns) for the same effect?
Since SMath syntax seems to be
mat(R1C1,R1C2,R1C3,R2C1,R2C2,R2C3,nROWs,nCOLS)
to get matrix of
R1C1 R1C2 R1C3
R2C1 R2C2 R2C3
I have been 'making' matrices to use in SMath via Excel in .csv files and text editor.
Using the .csv file already has everything formatted as needed. I take my data in csv, open it in editor, delete the CR/LF's so it becomes one long line and append the rows,cols) at the end. Copy and paste into SMAth and its there. My only trouble sometimes is counting the right number of rows/columns if I change things.
#3 已发布: 2015/12/8 17:19:45
Alexander O. Melnik
Alexander O. Melnik
127个赞,共498个帖子。
Alex-
Do you have a plugin code (C# or VB.NET) that would pass a string mat(R1C1,R1C2,R1C3,R2C1,R2C2,R2C3,nROWs,nCOLS) back to SMath without an error?
I have tried it in the past, but passing a simple string did not quite work...
#4 已发布: 2015/12/10 12:09:25
1,443个赞,共2,936个帖子。
How much slow? With importData.XLSX I can import a 1100x111 matrix of numbers in ~7-8 seconds (optimization: numeric)
The code is the same:
			// return selectionContent values to SMath
			List<Term> myResult = new List<Term>();
			foreach (string matValue in selectionContent)
				myResult.AddRange(Converter.ToTerms(matValue));
			myResult.AddRange(Converter.ToTerms(selectionHeight.ToString()));
			myResult.AddRange(Converter.ToTerms(selectionWidth.ToString()));
			myResult.Add(new Term(Functions.Mat, TermType.Function, 2 + (selectionHeight * selectionWidth)));
			// output to SMath
			return myResult.ToArray();
