Matrix math - Newbie question
Matrix math - Newbie question - How do I multiply 2 elements in a variable length matrix ? - 消息
#1 已发布: 2017/6/7 05:36:31
Peter J Francis
Peter J Francis
0个赞,共18个帖子。
Hi All,
I'm trying to create an input table for a worksheet I'm working on.
It's probably a bit of a newbie question but I'm new to SMath (and matrices !) so any help would be appreciated.
I want to perform calculations on the data in matrix BODY.
I've done this in BODY2 as a workaround but I'd like to find a way of doing it so I don't have to edit BODY2 everytime I add or delete a row.
Any help / guidance would be appreciated
Peter
TableRegion_Test.sm (10.96 KiB)已下载 1237 次。
Peter J Francis Twitter: @PeterJFrancis Thermal Engineer , Maker , Pilot
#2 已发布: 2017/6/7 07:13:32
1,443个赞,共2,936个帖子。
Hello Peter,
You can use a simple loop, like this:
TableRegion_Test.sm (10.15 KiB)已下载 1250 次。
Peter J Francis 2017/6/7 08:20:00
#3 已发布: 2017/6/7 08:19:21
Peter J Francis
Peter J Francis
0个赞,共18个帖子。
Thank you Davide
As I thought the answer was simple but I just couldn't see it.
I've been using Mathcad for a few years but have recently discovered SMath and am blown away by it.
Thanks again
Peter
#4 已发布: 2017/6/7 11:30:28
983个赞,共6,866个帖子。
Hello Peter !
Matrix maths is not same as "Matrix table".
I don't use much this feature for collecting data, but can demonstrate how to fill.
By same token, the attached "matrix Treasury might help in real "Matrix maths".
Welcome to Smath Community
TableRegion_Test jmG.sm (22.12 KiB)已下载 1256 次。
Utilities Matrix Treasury Copy.sm (336.08 KiB)已下载 1304 次。
Peter J Francis 2017/6/9 06:42:00
