"Not defined" but it is defined
"Not defined" but it is defined - 消息
#1 已发布: 2014/7/3 14:50:13
zapzapouch
zapzapouch
0个赞,共27个帖子。
Often SMath has a red box around something and says "x not defined" when I hover over it, but x is defined. In this case, the problem is that I typed "In" instead of "in", so it should be saying "In not defined", but it says "Req not defined", which seems like a bug to me.
Req not defined
Also, congrats on being able to handle units like "nV/√Hz" without screwing up.
#2 已发布: 2014/7/3 16:09:39
2,344个赞,共4,057个帖子。
组: Super Administrator
Please could you post an example? It will help to debug and make a fix. Thx.
#3 已发布: 2014/7/3 16:12:24
zapzapouch
zapzapouch
0个赞,共27个帖子。
Req not defined.sm (17.68 KiB)已下载 1484 次。
#4 已发布: 2014/7/3 17:08:29
1,443个赞,共2,936个帖子。
Is this bug: SS-89
#5 已发布: 2014/7/6 17:19:40
2,344个赞,共4,057个帖子。
Fixed in the scope of http://smath.info/bts/Issues/IssueDetail.aspx?id=89
Fix is available in the latest nightly build of SMath Studio.
Many thanks and best regards!
Davide Carpi 2014/7/6 17:55:00
