Decimal Symbol gets lost, problem with subscript
Decimal Symbol gets lost, problem with subscript - with European setting (, as decimal symbol, ; as arguments separator - 消息
#1 已发布: 2021/4/13 03:12:27
Martin_B
Martin_B
22个赞,共84个帖子。
Hi!
I use 0.99.7739, but the described problem occurs for a long time.
Sometimes I open a document and then somewhere in the document a comma (decimal symbol) in an expression gets lost. This happens from time to time.
The marked number thirteen should be 1.3 (shown as 1,3).
Looking into the file, you can find "1,3". I think this number was not correctly saved as 1.3 (transformed to 1.3).
But I have a pdf of the sheet with correct results, so this must happen while saving.
 <region left="315" top="801" width="200" height="66" color="#000000" fontSize="10">
      <math optimize="2">
        <input>
          <e type="operand">Δσ.s.equ</e>
          <e type="operand">Δσ</e>
          <e type="operand">λ.s</e>
          <e type="operand">1</e>
          <e type="function" args="2">el</e>
          <e type="operator" args="2">*</e>
          <e type="operator" args="2">:</e>
          <e type="operand">1,3</e>
          <e type="operand">1.3</e>
          <e type="operand">2</e>
          <e type="function" args="4">line</e>
        </input>
      </math>
    </region>
And furthermore a problem, which I think is related to the conversion . <-> , :
When I copy code an insert it somewhere else in the canvas or maybe in another line-block, the subscript "." is not rarely copied as ",". Even though the variable looks correctly with subscript.
So I get the message variable xy.sub is not existing. When I hover the mouse pointer over it I can see "xy,sub" with comma and of course that's something else than "xy.sub".
If you copy more lines than just a few, it can be really demanding to find the one wrong ",", because on screen everything looks fine.
2位用户喜欢此帖子
sergio 2021/4/13 04:49:00, Davide Carpi 2021/4/22 08:51:00
