SMath论坛 SMath Studio Questions How to work with common fractions? 1页(2条) How to work with common fractions? - 消息 转到最后一个帖子 #1 已发布: 2011/5/20 08:33:47 karepan 0个赞,共3个帖子。 组: User How to work with common fractions?2_3+7_9 results in 13_9, but not 1_4_9.Also I can't enter 1_4_9 in an expression, but only 13_9 #2 已发布: 2011/5/25 06:54:47 callmeishmael 4个赞,共15个帖子。 组: User Please use standard math notation, otherwise you'll make quite obvious errors.I guess that with _ you intend a division, hence /, 2/3+7/9=13/913/9 is also 1+4/9, not 1*4/9 or 1/4/9.The problem is not SMath... 1页(2条) 有新帖 无新帖
