1页(7条)
Variable not recognized when dividing - 消息
If I make a division where a variable is the denominator sometimes the variable is not recognized. See below, in the last row the variable is not recognized.
I have discovered that the bug depends on that the variable must have a subscript and also how I enter the equal sign.
If I enter the equal sign while the marker is still positioned next to the denominator then everything is alright.
But if I press right arrow and then equal sign the variable is not recognized.
Andrey Ivashov 2021/5/18 09:23:00
Thanks for taking the time to answer. Are you referring to SMath Studio version 6179? I forgot to mention in my first post but I am using the recently released stable version 0.99.7808
The exact key sequence to reproduce the bug is as follows:
A,L:10(Enter)
1/A,Tab(RightArrow)=
The following also produces the bug:
A,L:10(Enter)
1/A,L(RightArrow)=
Please try those sequences
A,L:10(Enter)
A,L:10(Enter)
1/A,L(RightArrow)=
Wrote... for users of your latest SS version ?
No, I meant, to see if you can confirm/reproduce the bug on another system. Since you seem to say that you could not reproduce the bug on your system. Or have I understood something wrong?
WroteSS 6179 Does NOT reproduce your bug.
Edit: Or do you mean that you have triaged the bug to have appeared after SS 6179 ?
A,L:10(Enter)
A,L:10(Enter)
1/A,L(RightArrow)=
Thank you very much!
Issue is reproduced. Will fix it asap.
Best regards, Andrey Ivashov.
Thank you very much, this is most likely the cause we were looking for here.
Thanks Andrey and Davide, I am very happy to have been able to help you on this issue
I have done some more testing and found that the key elements to reproduce the bug is that the last variable entered has a subscript and that "RightArrow" is pressed before pressing equal sign.
So for example:
A.L:3
3*A.L(RightArrow)=
2^A.L(RightArrow)=
So for example:
A.L:3
3*A.L(RightArrow)=
2^A.L(RightArrow)=
Issue is fixed. Will be included into the next release.
Thank you!
Thank you!
sergio 2021/5/19 04:45:00
1页(7条)
