define one vector from another
define one vector from another - apply a operation on each vector element with results given in a second vector - 消息
#1 已发布: 2013/10/16 11:27:48
Jay May
Jay May
3个赞,共10个帖子。
I would simply like to define a vector, then apply a operation to each element and have the results in a second vector. This seems to be simple in MathCad but I can't seem to get it in SMath Studio.
In MathCad
In SMath Studio I get this. I'm not shre just what this result is.
Any assistance would be appreciated.
Thank you.
#2 已发布: 2013/10/16 11:46:45
mb10
mb10
9个赞,共20个帖子。
The result is the sum of the squares of the elements, multiplied by two.
As far as I know SMath does not support vectorization (yet) so, in order to obtain what you need, you should use a for loop.
#3 已发布: 2013/10/16 12:01:48
325个赞和1个踩,共2,052个帖子。
If you are using vectors, then you can try mat2sys() and sys2mat()
#4 已发布: 2013/10/16 13:35:36
Jay May
Jay May
3个赞,共10个帖子。
Thank you mb10, I got the For..Loop to work it out. I was wondering if the vector options were available or not.
To omorr, the mat2sys() and sys2ma() looks like a clean method to acheive these functionality but how do I add the mat2sys() and sys2mat() functions?
Thank you.
#5 已发布: 2013/10/16 16:46:28
1,362个赞,共2,276个帖子。
mat2sys and sys2mat are part of the CustomFunctions plugin by Davide Carpi. You can install it using the extension manager (Tools> Plugins) or use the unofficial distribution with pre-installed plugins (link in the signature).
You also might consider using the Maxima Plugin (which requires Maxima to be installed on your system)
Radovan Omorjan 2013/10/17 01:06:00
