Gamma Functions
Gamma Functions - rapid speed with precision - 消息
#21 已发布: 2021/6/11 14:49:26
983个赞,共6,866个帖子。
Sanity checked vs Mathcad 11.
Cuts the mustard a bit finer than first version.
Γ(1,0)="Uncertainty" unsolved.
#22 已发布: 2021/6/11 14:56:09
600个赞,共1,381个帖子。
There is no uncertainty in gamma_r6.
Everything look correct with those numbers.
Γ(1)=1
γ(1,0)=0
Γ(1,0)=1
#23 已发布: 2021/6/11 16:33:56
983个赞,共6,866个帖子。
1. Example 3 ... added
2. Uncertainty solved for version not having 0 defined.
Gamma [overlord sr.6].sm (39.32 KiB)已下载 1214 次。
#24 已发布: 2021/6/12 02:20:08
1,139个赞,共1,805个帖子。
3. don't want to disrespect, Alvaro's is a single line awesome code.
4. mine has same algorithm with more features, with faster calculation.
Hi overlord, of course you don't. My codes are mostly pedagogical, not for optimized for speed nor accuracy or something else. It's good to have codes with that.
#25 已发布: 2021/6/12 10:15:48
600个赞,共1,381个帖子。
Thanks, inspired by your code using sum(), and eliminating some useless variable definitions;
I have managed to speed up 30% percent under linux. And should be more precise now.
Only the 15th decimal digit may differs, and this is only sometimes.
Regards.
gamma_r7.sm (28.8 KiB)已下载 1520 次。
#26 已发布: 2021/6/12 14:58:22
600个赞,共1,381个帖子。
Apparently solve() can't read product() too.
Had to change algorithm style for incomplete function.
Hopefully this is the last version.
Well, I have my doubts... (swh)
PS: solvers may not found an answer just because variable names, Razonar's idea implemented.
gamma_r8.sm (29.61 KiB)已下载 1520 次。
gamma_r8.sm (31.51 KiB)已下载 1543 次。 <---gamma_r8-2 (function variable revision)
#27 已发布: 2021/6/12 20:03:48
1,139个赞,共1,805个帖子。
Regards.
The algorithm is valid for Re(z) > 0. See this notes please.
gamma.sm (27.93 KiB)已下载 1985 次。
#28 已发布: 2021/6/12 20:20:04
983个赞,共6,866个帖子。
Can't be more right !
1. Smath Lanczos Davide code is 1/1 Keisan, Mathcad 11.
2. It supports imaginary argument.
3. It supports RootSecant.
4. Confirmed, your last Lanczos does not support RootSecant.
I haven't checked Alvaro suggestion.
#29 已发布: 2021/6/12 20:23:36
983个赞,共6,866个帖子。
... just a remark:
Mathsoft suggested use exp(,) instead of e^.
exp(,) more accurate/faster at kernel level.
#30 已发布: 2021/6/13 01:26:31
600个赞,共1,381个帖子。
Imaginary numbers supplicated.
Root Secant better than HT Davis. (last digit)
Graphing works for all functions.
Usually all solve methods works.
gamma_r9.sm (36.93 KiB)已下载 1940 次。
#31 已发布: 2021/6/13 11:18:41
983个赞,共6,866个帖子。
Your latest sr.9 is mostly red in SS 6179, takes Eternity.
Who cares ^308 ?
On the other hand, could be damned slow in practical applications.
Because not being built-in in native Smath ... proof:
Lanczos plots Hypergeometric but takes 1 min versus resident Gamma(x).
Why not use Lanczos as given by Davide ?
#32 已发布: 2021/6/13 15:26:22
600个赞,共1,381个帖子。
Who cares ^308 ?
- Who cares SMath 6179?
- My algorithm is faster than your examples.
- My Γ(x) prints hypergeom in less than a second, don't need integrated Gamma().
- Because my function has more features, and faster.
Your PC is slow, your SMath_6179 is slow and broken, your examples are slow.
Gamma [H.T. Davis, Lanczos_overlord].sm (62.36 KiB)已下载 1404 次。
Gamma [H.T. Davis, Lanczos_overlord].pdf (155.73 KiB)已下载 840 次。
