linterp help
linterp help - 消息
#1 已发布: 2024/1/17 10:19:48
GFDIntano
GFDIntano
0个赞,共8个帖子。
I'm pretty sure it's possible and saw it somewhere here. How do I put this in a single matrix, along with the descriptors like "roof angle, "1", "2E",...etc. and use it for interpolation. Well I can get by using a single column matrix as a work around but I guess I want a more compact looking solution, if that makes sense.
#2 已发布: 2024/1/17 16:00:11
600个赞,共1,381个帖子。
Look for InterpBilinear() function.
You can find more info in Reference Book.
InterpBilinear.sm (8.04 KiB)已下载 1587 次。
#3 已发布: 2024/1/17 16:03:13
GFDIntano
GFDIntano
0个赞,共8个帖子。
ohh didn't know about that. big thanks.
#4 已发布: 2024/1/17 18:02:20
983个赞,共6,866个帖子。
Surface plot is especially coded for your request.
Interpolate [Linterp, Spline2D] Copy.sm (201.25 KiB)已下载 1390 次。
#5 已发布: 2024/1/17 20:45:37
600个赞,共1,381个帖子。
Using linterp() with a function is another way.
Function selects column according to input.
linterp_select.sm (8.1 KiB)已下载 1579 次。
#6 已发布: 2024/1/18 10:10:49
GFDIntano
GFDIntano
0个赞,共8个帖子。
I'm quite satisfied with the InterpBilinear function. I'm exploring Jean's and overlord's additional suggestion but still it was already solved for me. Another question is that would that still work if I had to do interpolation in both the column values and row values such as in case below.
From what I understand, InterBilinear() seems incapable of doing what I aim to do. Do you have any suggestions?
#7 已发布: 2024/1/18 18:37:38
1,362个赞,共2,276个帖子。
#8 已发布: 2024/1/18 19:10:51
983个赞,共6,866个帖子。
From what I understand, InterBilinear() seems incapable of doing what I aim to do. Do you have any suggestions ?
If, I understand your request,
ForLoop algo style will do ... last example page 10.
Interpolate [Linterp, Spline2D].sm (212.07 KiB)已下载 1483 次。
#9 已发布: 2024/1/18 20:25:30
600个赞,共1,381个帖子。
On the contrary, InterpBilinear() does exactly what you seek.
It interpolates both row and column values.
PS: I added extra values to accommodate ≤ and ≥ boundaries.
#10 已发布: 2024/1/20 04:15:39
983个赞,共6,866个帖子。
Visit Samples for bidirectional interpolating Matrix.
