Newbie Question1
Newbie Question1 - 消息
#1 已发布: 2016/3/16 05:18:33
frapuano
frapuano
13个赞,共115个帖子。
as usually a simple question.
I want to define on the canvas a variable whose name is 1stPosition and inizialize its value to 1 .
What I would like to knwow is if it is by design that I achieve this ...
so it is always added a unit of measure when I enter with the keyboard s or S , so after this happens I need to delete what has been added and this continue to happen as I key as text something that is a predefined unit ..at least is what I see.
I am using the last night build.
Franco
#2 已发布: 2016/3/16 06:32:22
1,443个赞,共2,936个帖子。
Yes it is by design; a variable name cannot start with a number.
This is a standard almost everywhere (there are few exceptions); it keeps consistent and fast how to identify a variable both for humans and for the core (because you have to check only the first character).
You can use p1, pos1, Position1st, ...
If you define a variable with the same name of a unit, the variable s shown as first in the dynamic assistance, otherwise you have to type at least another character (if there is a 1-character unit or function already defined)
#3 已发布: 2016/3/16 08:02:09
frapuano
frapuano
13个赞,共115个帖子。
Davide
Thanks a lot for your feedback , now it is clear and I will follow your suggestions for the future variables naming .
The only thing that doesn't fit well is that on my Smath when I write the same as you ( so 12345 equal something ) ..I do not see the error description as shown in your screen shot.
Franco
#4 已发布: 2016/3/16 09:57:41
1,558个赞,共1,868个帖子。
It appears when you press F9.
Davide Carpi 2016/3/16 14:31:00
#5 已发布: 2016/3/16 11:14:07
frapuano
frapuano
13个赞,共115个帖子。
Shame on me ...
Davide Carpi 2016/3/16 14:30:00
#6 已发布: 2016/3/16 15:16:32
983个赞,共6,866个帖子。
frapuano 2016/3/16 17:13:00
