1 Pages (6 items)
Euler works - Runge-Rutta not - Why? - Messages
EK45 was Deified by Mathematica
Working code included.
Rocket-s-Euler.sm (122.44 KiB) downloaded 1268 time(s).
Thanks.
I have corrected myself
Rocket-s-Euler-RK.sm (87.35 KiB) downloaded 1182 time(s).
New question
Why this not works
Rocket-s-Euler-RK-full.sm (88.8 KiB) downloaded 1229 time(s).
New question
Why this not works
Your RK does work! Your Euler doesn't because you have defined the acceleration term to have two input variables, but only call it with one in the Euler routine!
Rocket-s-Euler-RK-full.sm (89.85 KiB) downloaded 1249 time(s).
Valery Ochkov 2023/12/31 17:02:00
WroteYour RK does work! Your Euler doesn't because you have defined the acceleration term to have two input variables, but only call it with one in the Euler routine!
Tanks!
Send me please the corrected file.
WroteWroteYour RK does work! Your Euler doesn't because you have defined the acceleration term to have two input variables, but only call it with one in the Euler routine!
Tanks!
I've now added the corrected file to my earlier reply.
Valery Ochkov 2023/12/31 17:43:00
1 Pages (6 items)
