Creating Matix - Easy Request
Creating Matix - Easy Request - 消息
#1 已发布: 2010/11/29 13:46:05
mstevens
mstevens
0个赞,共1个帖子。
When the create a matix dialog box opens, it would be nice if the first dimension were highlighted s.t. I could just type a number and that would be the dimension, likewise, if I tab to get to the next dimension it should then highlight/select it so that one does not have to manually highlight the number to change it. This is standard Microsoft Windows behavour. Currently to make changes to the number the number must be selected and overtyped manually or manually deleted then replaced.
Hope the the suggestion is clear.
Melvin Stevens
