SMath Studio 0.98.6325 (26 April 2017)
SMath Studio 0.98.6325 (26 April 2017) - 消息
#1 已发布: 2017/4/26 16:03:46
2,344个赞,共4,057个帖子。
组: Super Administrator
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_98_6325.Mono.tar.gz (1.24 MiB)已下载 2800 次。
SMathStudioDesktop.0_98_6325.Setup.msi (2.11 MiB)已下载 5683 次。
10位用户喜欢此帖子
sergio 2017/4/26 16:42:00, Arie 2017/4/26 16:52:00, Davide Carpi 2017/4/26 19:15:00, frapuano 2017/4/27 01:33:00, Radovan Omorjan 2017/4/27 03:12:00, Mikaël 2017/4/27 06:57:00, IVR 2017/4/27 07:27:00, Вячеслав Мезенцев 2017/4/27 12:03:00, NDTM Amarasekera 2017/4/28 04:19:00, Martin Kraska 2017/4/29 09:04:00
#2 已发布: 2017/4/28 07:34:42
1,443个赞,共2,936个帖子。
Built-in function Clear(..) implemented to remove variables/units/functions defined above on the Worksheet;
Function Clear(...) previously available in Custom Functions plugin removed from that extension (from this version of SMath Studio onwards)
#3 已发布: 2017/4/28 11:08:31
karlashnikov
karlashnikov
1个赞,共2个帖子。
Due to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location.
The screenshot is made on a win10 13" macbook pro with definitly not 96dpi.
#4 已发布: 2017/4/28 13:00:09
1,443个赞,共2,936个帖子。
I guess you have to remove image region plugin.
#5 已发布: 2017/4/28 13:21:32
karlashnikov
karlashnikov
1个赞,共2个帖子。
Thank you, that's it!
Davide Carpi 2017/4/28 13:34:00
#6 已发布: 2017/4/29 09:23:41
1,362个赞,共2,276个帖子。
Clear() doesn't work with vectorize(), whereas IsDefined() does.
It is not really essential to have that feature but the response indicates successful execution, which is wrong.
Clear.sm (29.29 KiB)已下载 1781 次。
IVR 2017/4/29 14:52:00
#7 已发布: 2017/4/30 19:38:29
983个赞,共6,866个帖子。
Hello Martin,
Clear(,)=1 looks a Matlab code that clears the work space
from previous assigned values. Thus, it renders the algorithm
of the "work space" scalar wrt their respective scalar running
iterators x, y ...
In the attached "Fourier Quantum"... x,y are returned scalar
only for the double integrator. The Mathcad double integrator
is coded implicit of 'x,y' scalar ... much simpler but less
educative.
Fourier Quantum CoC Copy.sm (97.81 KiB)已下载 1817 次。
