1页(4条)
problem with if - programming if does not show else - 消息
Maybe this is a very dumb question but how can I add a "if else" structure?
When I click the "if" in the programming toolbar no "else" is added.
OK, this happens in last version. I checked in build 8151 it does not occur, seems like a bug.
The if function now has a variable number of operands. The side panel and the dynamic assistant insert the binary form by default. Just type one or more argument separators immediately after insterting the function and see what happens. Likewise you can delete operators by typing backspace.
The binary form is a compact notation if you don't need the else clause.
However, I prefer the cases() function from the custom functions plugin, because it is more compact.
Oscar Campo 2022/10/21 12:29:00
Ah-h! Good to know. I was scratching my head on this one!
Thank you!
Norm
Thank you!
Norm
1页(4条)
