Why I have an error?
Why I have an error? - Messages
#1 Posted: 2024/1/29 16:41:35
Valery Ochkov
Valery Ochkov
66 likes in 682 posts.
When x1(t)=sin(t) - no problem.
When x1(t) is my function - an error!
See please the attach.
Three-Planets (Mathcad Block).sm (38.29 KiB) downloaded 1371 time(s).
#2 Posted: 2024/1/29 17:31:21
1,353 likes in 2,264 posts.
This is because the solution functions are defined using interpolation. The interpolation functions have the X and Y vectors and the value of x as arguments. You try to provide a vector for x. Vectorize can handle only matrix arguments of the same size and successively calls the function with the j-th element of each vector.
So vectorize would require your x vector to be of the same size as the data vectors. Even in this case this probably will fail because the data would be reduced to a single X_i and Y_i.
Therefore, you have to use a loop.
#3 Posted: 2024/1/29 23:12:24
Vectorize works fine in this document.
Three-Planets.sm (41.7 KiB) downloaded 1327 time(s).
#4 Posted: 2024/1/30 00:28:13
Valery Ochkov
Valery Ochkov
Sorry - no. See please the attach
Three-Planets.sm (39.1 KiB) downloaded 1363 time(s).
#5 Posted: 2024/1/30 21:47:53
As I open your returned document,
both vectorize are red ... click on either one ... Bingo
