lsoda
lsoda - Adams/BDF ODE solver for stiff or nonstiff systems - 消息
#1 已发布: 2019/1/20 21:29:14
1,558个赞,共1,868个帖子。
lsoda (Livermore Solver for Ordinary Differential Equations)
SMath Studio compatibility SMath Viewer compatibility mono compatibility Platform Extension page Sources
Functions list:
显示剧透
lsoda(ics, xmin, xmax, steps, ode) solves the initial value problem for stiff or nonstiff systems (uses Adams/BDF methods).
Arguments:
  • ics is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE).
  • xmin and xmax are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
  • steps is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
  • ode is a vector function of the form D(x,y) specifying the right-hand side of the system
Options:
- AbsTol - absolute tolerance parameter, default value 10⁻⁷.
- RelTol - relative tolerance parameter, default value 10⁻⁴.
Click to enlarge Click to enlarge
Links:
1. Solving Stiff ODEs.
2. Serial Fortran Solvers for ODE Initial Value Problems.
lsoda.integrate.sm (10.55 KiB)已下载 1922 次。
lsoda.kinetic1.sm (7.74 KiB)已下载 1843 次。
lsoda.kinetic2.sm (10.74 KiB)已下载 1851 次。
lsoda.kinetic3.sm (10.42 KiB)已下载 1810 次。
lsoda.test1.sm (11.63 KiB)已下载 1836 次。
lsoda.test2.sm (11.3 KiB)已下载 1829 次。
lsoda.Arenstorf Orbit.sm (15.45 KiB)已下载 1997 次。
lsoda.Amplitude detector.sm (20.15 KiB)已下载 1886 次。
lsoda.integrate.pdf (87 KiB)已下载 1057 次。
lsoda.kinetic1.pdf (74.4 KiB)已下载 1112 次。
lsoda.kinetic2.pdf (87.83 KiB)已下载 974 次。
lsoda.kinetic3.pdf (82.48 KiB)已下载 931 次。
lsoda.test1.pdf (87.33 KiB)已下载 981 次。
lsoda.test2.pdf (90.52 KiB)已下载 961 次。
lsoda.Arenstorf Orbit.pdf (93.42 KiB)已下载 1086 次。
lsoda.Amplitude detector.pdf (148.2 KiB)已下载 1058 次。
See also:
● [topic=726]Mathcad Toolbox[/topic]
● [topic=1918]DotNumerics[/topic]
● [topic=13809]SADEL[/topic]
● [topic=1970]Matlab C++ Math Library[/topic]
● [topic=17063]OSLO[/topic]
● [topic=1997]GNU Scientific Library (GSL)[/topic]
4位用户喜欢此帖子
NDTM Amarasekera 2019/1/20 22:20:00, Radovan Omorjan 2019/1/21 03:41:00, frapuano 2019/1/21 03:54:00, Davide Carpi 2019/1/21 11:00:00
#2 已发布: 2020/12/2 08:22:55
francesco88
francesco88
1个赞,共34个帖子。
Hello Viacheslav,
I attach here the two different file, lsodaMAP3 have the problem solved, lsodaMAP2 show the error.
SMath version 0.99.7610.506
lsoda version 0.1.7175.9902
未找到文件。 未找到文件。 未找到文件。
Playing a little bit in the lsodaMAP2 I was able to make it show the chart with the "problem".
Let me know if you need anything else!
All the best
Francesco
Veniamo da molto lontano e andiamo molto lontano! Palmiro Togliatti
#3 已发布: 2020/12/2 17:49:33
1,558个赞,共1,868个帖子。
The problem is in the X-Y Plot plugin. It cannot display the input data because it is outside the normal bounds. Also in the document somehow the min and max values of the axis are the same, which also results in an error. It will take a time to fix this. I haven't tested the plugin on bad data much.
#4 已发布: 2021/12/9 15:00:37
1,558个赞,共1,868个帖子。
Plugin updated.
Changes:
- added support for ODE systems in mathematical form;
- refactored.
sergio 2021/12/9 18:35:00
#5 已发布: 2021/12/23 09:53:30
1,558个赞,共1,868个帖子。
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin. As far as I understand, the algorithm used in this solver is the same as used in Odesolve: Adams/BDF. This can be seen from the comments in the source code. If I can port this code to c#, then we will have the same solver as in Mathcad. I want to include it as a default solver in Mathcad Toolbox plugin.
sergio 2021/12/23 14:47:00
