Matrix size defined by variables
Matrix size defined by variables - Messages
#1 Posted: 2018/3/23 11:30:17
Rens
Rens
0 likes in 4 posts.
Does anyone know if it is possible to define a variable which will determine the size of a matrix. From where on the created matrix is again an input and not an output.
For exaple:
n:=1 (number of rows)
m:=3 (number of koloms)
creates a matrix of 1 kolom and 3 rows as below
y:= [* * *]
where the '*' are emty and can be spicified by the user.
Beste regards,
Rens Servais
#2 Posted: 2018/3/23 11:57:07
Arie
Arie
94 likes in 285 posts.
Check out this example.
Matrix.sm (7.39 KiB) downloaded 1090 time(s).
#3 Posted: 2018/3/23 12:34:01
Both ways: empty and '0'
#4 Posted: 2018/3/23 15:18:56
CBG
CBG
78 likes in 312 posts.
Other solution
#5 Posted: 2018/3/24 04:47:24
Rens
Rens
0 likes in 4 posts.
Thanks Jean Giraud,
Your solution suits the best for me, but I can not reproduce it. See below. What do I do wrong?
Beste regards,
Rens
Matrix.sm (31.46 KiB) downloaded 1066 time(s).
#6 Posted: 2018/3/24 07:13:25
1,441 likes in 2,932 posts.
Do one of the following:
  • press CTRL+M
  • write mat(
  • write mat and press the tabulation key
  • on the right side of the windows, click on the first element of the Matrices toolbox
  • use the function dialog (press CTRL+E or choose the Insert > Function menu item or click on the fx symbol from the toolbar) choose the Matrix and vector group and search mat (click on whatever item and press m), then double click it or click on the insert button
Andrey Ivashov 2018/3/24 07:39:00, frapuano 2018/3/24 08:58:00
#7 Posted: 2018/3/25 23:10:14
That will work for you. At this point, you can address any element.
The empty matrix has almost no use.
#8 Posted: 2018/3/25 23:28:48
Plenty of matrix manipulation in there.
There are more and more, that should help.
Utilities Matrix Treasury_2 Copy.sm (109.43 KiB) downloaded 1039 time(s).
Utilities Matrix Treasury_0 Copy.sm (376.52 KiB) downloaded 1077 time(s).
Utilities Matrix Treasury_1 Copy.sm (372.39 KiB) downloaded 1060 time(s).
