Unexpected error
Unexpected error - 消息
#1 已发布: 2012/9/6 11:59:13
Samira
Samira
0个赞,共1个帖子。
Hi everybody,
I am a very new user of SMath. I created an sm file for calculating stiffness matrix of a beam. After I ran the program I was trying to change one input format and I suddenly closed the sm file before it finished calculating. After doing that I am no more able to open my previous sm file. The error message is " Unexpected end of file has occurred. The following elements are not closed: result, math, region, regions. line 46280, position 26".
If anybody know how to retrieve the old file Please help me.....
#2 已发布: 2012/9/6 15:20:16
Infinity
Infinity
3个赞,共30个帖子。
Hi Samira,
I already faced the same problem. If you do not have a backup, there is no way to restore the file.
This is a bug within SMath. Avoid saving the worksheet while it is calculating or train yourself to click the "Interrupt processing" button before you click the save button.
Infinity
#3 已发布: 2012/9/6 18:08:51
1,443个赞,共2,936个帖子。
Hi everybody,
Please attach your damaged file to the post, we can recover a part of it (see here)
regards,
w3b5urf3r
#4 已发布: 2015/9/30 06:15:19
Dane van Tonder
Dane van Tonder
0个赞,共1个帖子。
Hi
I have a similar error my file wont open with the unexpected end of file error.
I have attached it if possible it will be appreciated if you could try recover it.
Dane
Portal Design SANS.sm (1.38 MiB)已下载 1478 次。
#5 已发布: 2015/9/30 08:28:57
1,443个赞,共2,936个帖子。
Done!
Portal Design SANS_RECOVER.sm (1.38 MiB)已下载 1490 次。
#6 已发布: 2015/9/30 23:31:10
983个赞,共6,866个帖子。
Crashing unexpetedly is not particular to Smath.
Often, it's not possible to trace the cause.
In that respect, Smath is superior to Mathcad,
you lose only what has not been saved, but that
may depend upon your PC version. With XP, the
most recent restore point is not far from where
it crashed.
jmG
