Stable: SMath Studio 0.99.6622 (17 February 2018)
Stable: SMath Studio 0.99.6622 (17 February 2018) - 消息
#1 已发布: 2018/2/17 10:06:18
2,344个赞,共4,057个帖子。
组: Super Administrator
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_99_6622.Mono.tar.gz (1.26 MiB)已下载 4290 次。
SMathStudioDesktop.0_99_6622.Setup.msi (2.13 MiB)已下载 22084 次。
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
Other files
10位用户喜欢此帖子
Василий Николаевич Храмушин 2018/3/3 06:07:00, sergio 2018/2/17 12:11:00, Radovan Omorjan 2018/2/17 12:42:00, IVR 2018/2/17 14:14:00, Вячеслав Мезенцев 2018/2/17 14:21:00, Martin_B 2018/2/17 15:42:00, Davide Carpi 2018/2/17 19:43:00, Denis Nikitin 2018/2/20 03:37:00, NDTM Amarasekera 2018/2/17 10:25:00, Igor Skarine 2018/2/17 13:08:00
#2 已发布: 2018/2/17 12:48:08
2,344个赞,共4,057个帖子。
SMath Studio in the Cloud updated to use SMath Core 0.99.6622. Both features: equations breaking and inserting special symbols into equations - are now supported in Cloud.
3位用户喜欢此帖子
Igor Skarine 2018/2/17 13:06:00, Davide Carpi 2018/2/17 19:43:00, frapuano 2018/2/17 15:24:00
#3 已发布: 2018/2/19 14:43:10
2,344个赞,共4,057个帖子。
Almost forgot to highlight the following important change done in this release:
errors_behavior_1.sm (4.43 KiB)已下载 2228 次。
3位用户喜欢此帖子
Вячеслав Мезенцев 2018/2/20 01:24:00, sergio 2018/2/19 17:15:00, Davide Carpi 2018/2/19 20:36:00
#4 已发布: 2018/3/6 13:38:59
Doug Schickler
Doug Schickler
0个赞,共1个帖子。
Hi Andrey
Very surprised that an error popped up in the latest build. Maybe also the one before, not sure.
For your info, here is the S' definition
It seems that somehow these last two builds cannot find a value of the matrix coordinates indicated. It worked fine in .6484 from October, which I have gone back to. I can send you the file, but I would prefer to do so privately.
Love this program
Doug Schickler
#5 已发布: 2018/3/6 15:11:13
2,344个赞,共4,057个帖子。
Hello.
Please send a worksheet to me so I could reproduce and fix this issue. E-mail is specifield into About dialog of SMath Studio.
Thank you for the report!
#6 已发布: 2018/3/7 23:59:51
983个赞,共6,866个帖子。
It seems that somehow these last two builds cannot find a value of the matrix coordinates indicated.It worked fine in .6484 from October, which I have gone back to.I can send you the file, but I would prefer to do so privately.
That it worked 6484, I doubt as it shows incorrectly dressed.
If you had a result => most probably erroneous.
On the setup "rotation*matrix", Smath [4356, 6179] displays an error message.
The rule Matrix*Rotation is universal, not commutative.
UnknownConfidential.sm (202.5 KiB)已下载 2180 次。
Rotate Breather [4 Orientations].sm (1001.04 KiB)已下载 2016 次。
#7 已发布: 2018/4/2 17:25:41
RickH
RickH
0个赞,共5个帖子。
I have noticed that if I open a .sm file which has file properties set to "read only", the program will crash if I press the "save" button. It would be nice if it instead prompted to "save-as" in that scenario, or just notify the user that the file is read only so the user can then perform a save-as instead. This is on Windows 7. Thanks.
#8 已发布: 2018/4/3 06:08:05
1,443个赞,共2,936个帖子。
Already fixed in SS 0.98.6626 and later nightly builds, will be part of next stable release.
