"on error" test image rotate
"on error" test image rotate - "on error" test image rotate - 消息
#1 已发布: 2016/4/16 14:42:32
983个赞,共6,866个帖子。
Hello Mike,
If you can make it work at the "on error" that Smath 5346 does not have
the Smath community will heritate a nice piece of work that I heritated
from Paul W. [Mathcad 11 Collaboratory]. If there is a way to make it
work in 5346, I will most appreciate. The R, G, B are all in the collapsed
areas, nothing to download. The coding stops at the empty place holders.
Thanks for your kindly cooperation, good luck.
Rotate Image.sm (431.26 KiB)已下载 1547 次。
#2 已发布: 2016/4/16 19:50:06
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
rotate() tries to get fourth col of a matrix having only two cols:
trace.sm (100.24 KiB)已下载 1537 次。
Actually, I didn't try to understand the algo yet, so I have no clue how to improve it.
Edit:
in the original algo, there's no line like
s:augment(col(s,2),col(s,4))
Removing it gives another error: j becomes -14, and this index isn't OK as a matrix col.
Edit 2: here it is, should work for 5346: Rotate Image.sm (407.7 KiB)已下载 1564 次。 (updated for 2x speed using eval()).
Edit: and here is the colored version (great thanks to Alex Melnik): Rotate Image+color.sm (414.52 KiB)已下载 1552 次。
С уважением, Михаил Каганский
