String function in user function
String function in user function - 消息
#1 已发布: 1980/7/1 10:31:40
Edward Ulle
Edward Ulle
21个赞,共182个帖子。
I tried from my computer at work to enter a string in SMath Live and could not. When ever I type " the unit cursor appears.
Ed
#2 已发布: 2011/12/7 19:41:32
Edward Ulle
Edward Ulle
21个赞,共182个帖子。
It appears string functions findstr and subst don't work in user functions, maybe others. Probably because when the function is created the parameter is null not a string. The string functions must test for a string.
Ed
#3 已发布: 2011/12/8 05:36:53
325个赞和1个踩,共2,052个帖子。
Hello Ed,
Quite strange, but this will work as a workaround.
[LIVE width=305 height=338]http://smath.info/live/?file=3340[/LIVE]
Actually, it seems that line() is needed in order to use string functions>
[LIVE width=311 height=203]http://smath.info/live/?file=3342[/LIVE]
#4 已发布: 2011/12/8 18:18:06
Edward Ulle
Edward Ulle
21个赞,共182个帖子。
Radovan,
I'm using 0.89 Stable and I tried to duplicate your example and get the same error message. Thanks.
Ed
#5 已发布: 2011/12/10 09:17:42
Edward Ulle
Edward Ulle
21个赞,共182个帖子。
Still fiddling with this I can't find a string function that will work in a user function. Using 0.89 Stable on Win 7.
PS
Something else weird. In SMath Live when I type double quote I get units cursor. I can't enter strings in SMath Live. Radovan, how did you do it?
Ed
#6 已发布: 2011/12/10 13:06:41
Hello Ed,
Do not know about this. It might be a bug. My advice is to use the 0.89.8 until the release of the next version.
I do not have problems with it. When I insert double quotes there can be string inserted. On the other way, it might be faster to make a *.sm file first and then to use "Upload page (.sm)" from the SMath Studio Live palette.
Edward Ulle 2011/12/10 15:16:00
