Insert a row into an existing Matrix
Insert a row into an existing Matrix - Best way to insert a row / col into matrix - 消息
#1 已发布: 2015/3/21 13:27:34
Ryan Freund
Ryan Freund
20个赞,共339个帖子。
What is the "best" way to insert a row into an existing matrix.
Say I am looping through a matrix and I want to insert a row (or column) of elements because of some other criteria. Then continue to loop through the matrix, adding rows when required by the conditions set. What is the best way to do this?
Thanks
#2 已发布: 2015/3/22 14:31:34
1,443个赞,共2,936个帖子。
You can try using stack() and submatrix() or with the Linq extension
