Parsing Name Error
Parsing Name Error - 消息
#1 已发布: 2015/10/28 16:47:00
Ryan Freund
Ryan Freund
20个赞,共339个帖子。
Can someone help fix the error in this SMath file and possibly help me understand where the error is coming from.
Here is the error:
http://1drv.ms/1NBneog
These images never work for me (see below). I'm trying to share them from onedrive. Is there a way to do this?
Thanks!
Gravity - Walls - Exterior - 2x6 Option.sm (700 KiB)已下载 1450 次。
#2 已发布: 2015/10/28 17:57:11
Ryan Freund
Ryan Freund
20个赞,共339个帖子。
引用
It seems you are adept of all in one. This strategy, IMHO, gives huges file and the risk of braking something.
Yes you are correct. I just can't stand the thought of having to open and print 100 .sm files. However, I am realizing that there needs to be a balance. I can't do all in one. Although as .sm gets "stronger" there should be less chance of braking. Although the probability of me making mistakes still remains high I suppose.
If there was a batch print than I could see connecting the files. I like using the "include" to connecte the files but maybe if I get better with data files, I could try this. Do you have an example that you could share?
Thank you
