1页(8条)
[Custom Functions] Linear Interpolation - 消息
First of all I don't know if this method is supported, it would be very useful if not.
So if this is not a feature please forgive me because I considered as a bug.
The "InterBilinear" function gives wrong results if matrix is used for x or y value.
interpolation.sm (15.61 KiB)已下载 1524 次。
Davide Carpi 2019/7/5 04:41:00
WroteFirst of all I don't know if this method is supported, it would be very useful if not.
Mathcad Bicubic can't be reproduced, even "if it could be"
would be useless whereas Smath does not have Matrix 3D plot [only 3 cols].
Your metric X,Y directions aren't correct. You can metric like center as well.
You can have surface plot, only... rotate the plot at will.
interpolation [Oterwise metric X, Y Directions].sm (33.32 KiB)已下载 1337 次。
Hi overlord. I prefer source code in a high level language, even it could be slowest.
interpolation bilinear source code.sm (26.59 KiB)已下载 1508 次。
WroteYou can have surface plot, only... rotate the plot at will.
You can have it otherwise from the X_Y surface plot.
interpolation [Oterwise metric X, Y Directions].sm (95.7 KiB)已下载 1352 次。
WroteYou can have it otherwise from the X_Y surface plot.
... you can create the matrix and the X, Y directions at will.
Then just interpolate ... Spline linterp has the virtue equivalent quadratic.
It would be mistake to cspline.
Bilinear SplineInterp [Construct USER].sm (12.86 KiB)已下载 1267 次。
It is a bug, thank you! 4th and 5th argument type isn't checked, therefore (unintentionally) vector math applies.
Two things here:
1. The 4th and 5th arguments are presented in reverse order compared to Mathcad
2. The two dimension spline coding is from unknown source
...neither from either Smath [linterp, cinterp, ainterp]
...could be from erroneous quadratic source code.
As given in the attached: Spline(x,y,M) assumed = Mathcad Bicubic2D(x,y,M,vx,object)
At this point, you can spline/plot/rotate the surface as suggested before
Bilinear SplineInterp [Construct USER].sm (24.61 KiB)已下载 1305 次。
WroteTwo things here:
InterpBilinear(vx,vy,M,object,vector) ... does not collect"vector wise"
InterpBilinear(vx,vy,M,object,valueX) ... correct
That is the answer to the "bug",
1页(8条)
