1页(3条)
num2str vs decimal numbers - ComboBoxList numeric evaluation - 消息
Hello all, pardon me if this is submitted in the wrong place, but I think I have come across an issue that could be improved. I was using the ComboBoxList, populated by a 1-column matrix of beam depths to filter input options for a beam design worksheet. I'm also using the SQL plugin in conjunction with that. However, American WT sections have decimal designations such as "WT10.5x22". If I'm picking a size that uses a whole number designation, everything works fine. If I try picking the 10.5" depth to see those options in the next ComboBoxList, then it errors out. It seems the ComboBoxList is outputting the selected entry as a fraction such as 21/2 instead of as a decimal like 10.5. I've tried various option to try to force the decimal output, keeping the numeric entries I had in the source data. My original SQL functions I was using had the Num2str function to convert the selected value to a string and concatenate it with a SQL search query. If the ComboBoxList selection is output as a fraction, then it messes up the search string. I don't need to use the selected value for any calculations in this worksheet, so I worked around this issue by changing the d.nom_WT matrix to all string entries so the ComboBoxList doesn't evaluate them symbolically. However, I was just wondering if it wouldn't be helpful to have a third option in the ComboBoxList settings where it could also evaluate as "numeric" in addition to the current options of "Symbolic" or "Numeric + Symbolic". Hopefully, the attached screenshots help make sense of all this. Thanks!
Jason
未找到文件。未找到文件。
Jason
未找到文件。未找到文件。
Jason McCool
Robbins Engineering
Little Rock, AR, USA
Hello Jason,
The issue is not related with ComboBoxList region, is about num2str(); try using var2str() from Custom Functions plugin instead.
frapuano 2016/12/15 08:32:00
Ah, OK. I didn't see that option in there. Thanks!
Jason
Jason
Jason McCool
Robbins Engineering
1页(3条)
