1页(4条)
definite integrals - 消息
any more progress on definite integrals (symbolic answers to things like int(x^2,x). similar to something like a ti89 can do.. I read a post from 2009 saying you guys were working on it. I have tried in the newest version unsuccessfully but I could be doing something wrong.. If so please let me know because if that is the case I can see some huge advantages to using this for my homework assignments! keep up the great work!
thanks,
Brandon
thanks,
Brandon
Hello Brandon,
There were lots of post on this and similar subjects. See this post http://en.smath.info/forum/default.aspx?g=posts&m=3379#post3379 or this one http://en.smath.info/forum/default.aspx?g=posts&t=1025 for instance, please.
As far as I understood, symbolical integration and some other things specific for CAS system will be available in SMath only when someone is willing to make a plugin, or to improve the SMath's own symbolic engine. I think that nobody can answer, at the moment, when that could be expected.
Radovan, you're absolutely right.
Regards.
Regards.
1页(4条)
